#29111 04/22/20 01:50 AM
I Have an issue with a 211 I don’t think it’s seeing the door closed limit. Just keeps showing the doors trying to close I tried adjusting the limit and suspected the sensor when I pushed on the plug on the board the u i t showed my doors where closed cut the car loose made about 4 trips then cut out again??? Now I’m suspecting the door board are these still available?
boomer #29114 04/22/20 02:38 PM
Liscensed Journeyman
Belt/Chain Tension, Sheave bearing, all good?
boomer #29120 04/22/20 09:30 PM
Yes all looks good I think the door card is bad I would get it to run for like half a dozen trips then it would lose dcl I was wiggling the connector on the door board where the limit sensor plug in and it would make back up and doing unplugged everything to check for loose connections now nothing comes up on the UIT. Fuse on the board is good. I got a new board coming so I will try that.
boomer #29174 04/30/20 03:26 PM
Got the new door board today and installed it and the uit isn’t lighting up. I noticed I don’t have a heart beat either? Checked the fuse on the board and controller fuses all good. Any ideas why I’m missing the heart beat or why the uit isn’t working?
boomer #29176 04/30/20 11:40 PM
Is it on access?
boomer #29177 05/01/20 12:13 AM
I had a 211 board that shorted layers in the board after a power failure in the bldg.
boomer #29184 05/01/20 01:46 PM
It’s not on access. I tried the new board which I found out is a rebuilt one from unitec in the running car next to the one that is shut down and had the same results uit never illuminated and heart beat led was on solid. Also tried plugging into the door operator with 2 different Otis tools and could not communicate. I’m thinking it’s a bad board info I have says if there isn’t a heartbeat replace pcb?
boomer #29185 05/01/20 02:05 PM
I was curious when you said you had a new board coming. I'm pretty sure the door boards for the I motion's are obsolete. I tried to get one last year and ended up having to get a rebuilt one as well.
ABE #29223 05/05/20 10:41 PM
Got another board today put it in and everything worked like it was supposed to. Turns out the first board unitec sent us was a bad board. Thanks guys
PHP: 8.3.33 Page Time: 0.024s Queries: 32 (0.005s) Memory: 3.0343 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 19:20:01 UTC
