0 members (), 46 guests, and 3 robots.
Page 1 of 3 1 2 3
#2387 01/22/12 02:27 AM
gogetitdone
gogetitdone
hy guys I receive a toy a330A but it's leaking bad on one side do you know if I have to unbolt the jack out of the hoistway or do you know a way to do the job in the pit I have seen some new stuff and wonder if the engineers thought about leak ! thank you
latham #2393 01/23/12 02:22 AM
This is what I've heard people saying about doing this job, it's a PIA. Hang car, use a compressor to blow oil back to the tank, pull the jack and change the packing out in the floor. Apparently there are some snap rings that you need to deal with carefully. Sorry but I'm not a repair guy.
E-man #2400 01/23/12 02:47 PM
gogetitdone
gogetitdone
I thought if I had to hang the car,do you thing the weight on the jack unbolted will return enough oil close to the shut valve ,well thank for your help i just can believe we install those maintenance repair nightmare after all when you do a few off yhem it might be routine, well thank for helping me
latham #2431 01/28/12 03:04 AM
You don't need to remove the jack to replace packings. Easiest way is to contact D.L. Martin and have them fax over instructions on how to do it. It is not nearly as hard as you think. Martin is the manufacturer of the jacks for Schwindler elevator
Schmitty74 #2709 02/23/12 01:48 PM
You don't need to blow oil back. First order kit from Schindler or dl Martin. It contains a type of stand to hold piston up inside of the cup. Place car on sticks and close shut offs. Use small hoist( I hang it off a c clamp on the triangular metal near jack). Use small piston clamp to hoist piston sections neat a time. There are very small set screws all around each head ! Remove the snap ring at bottom and hoist piston slowly. Use vacuum to suck up the oil that comes out( should only be about 10-15 gallons). Place stand under piston and hammer down head. Hoist piston up again and remove head from stand. Repeat for all sections.
Iuec4 #2711 02/23/12 07:44 PM
UW BADGER
UW BADGER
V Offline
Its easier to remove the Set screw at the head and install a nipple to blow back the oil to the tank......... vs. sucking up the oil.
Vatorman15 #2716 02/23/12 11:39 PM
We have two of these units and we just gave a proposal to replace the packing in one. When they approve our proposal and we schedule and finish the work I'll write in my experience.
Schmitty74 #30758 03/10/21 10:29 PM
Gted
Gted
Hi there, i am scheduled to do a 3 stage inverted Friday, i tried to reach out to DL Martin which directed me to Adams then told me to contact Schindler. Is there someone who has the instruction manual for the seal repalcement and would be willing to share it? I really dont want to wing this one. Thank you.
latham #30759 03/10/21 11:07 PM
PM or post email
solidstate #30789 03/17/21 11:35 AM
Originally Posted by solidstate
PM or post email
Solidstate, I’d love a copy of those instructions?
[email protected]
2nd generation elevator man.
Chainring #30808 03/20/21 06:14 PM
Me too please [email protected].
latham #30817 03/24/21 02:33 AM
Count me in [email protected]
solidstate #30820 03/24/21 12:29 PM
I’d love a copy of those instructions sir
[email protected]
latham #30822 03/24/21 04:51 PM
I'd like a copy as well if you don't mind!
[email protected]
solidstate #30823 03/25/21 06:48 PM
Me as well please [email protected]
solidstate #30829 03/26/21 04:08 AM
[email protected]
Thanks buddy
latham #30830 03/26/21 06:36 PM
I would really appreciate any info on this topic
[email protected]
latham #31139 05/19/21 11:27 PM
latham #31151 05/24/21 04:41 PM
I'd like a copy of those instructions too please. [email protected]
latham #31153 05/24/21 07:36 PM
I'd appreciate getting a copy of those instructions as well. Thanks in advance! [email protected]
Page 1 of 3 1 2 3
PHP: 8.3.36 Page Time: 0.051s Queries: 55 (0.017s) Memory: 3.1162 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 02:09:11 UTC
