#29377 06/04/20 02:52 AM
A question for all.
I am trying to determine the situations where it is absolutely necessary to operate an elevator when you are in the pit, traction or hydro. By absolutely necessary I mean exactly that. There is no other way, it is not a question of convenience.
How do you do it? Pit inspection station? second guy with car top inspection?
BillS #29378 06/04/20 04:16 AM
Do you mean like replacing lower roller guide wheel(s) in a 6’ pit?
I’ve always utilized a second mechanic as there really is no other way to get this replacement done by ones self safely unless there is a 6’ ladder at your disposal. I suppose any work where the unit has to be lowered to the point where a safe and adequate exit point cannot be provided would require a second mechanic to run the car.
Hope that example addresses your question.
BillS #29379 06/04/20 10:11 AM
Second guy always... With the exception of a new install in which you'd have temp buttons and could run the car yourself while in the pit... for fully auto elevators that have work to be done that requires you to be in the pit i always have a helper that is knowledgeable...they'll either run the car from the car top inspection station or from bottom access.
BillS #29394 06/05/20 03:27 AM
2nd guy, all the time, every time. Changing bottom guides, repacking ingrounds, trouble shooting noises while coming into bottom floor only, doesn't matter.
PHP: 8.3.33 Page Time: 0.032s Queries: 22 (0.007s) Memory: 3.0114 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 23:59:35 UTC
