Posts40,945
Elevator_Logic
Elevator_Logic
I have attached a picture of the relay/switch in question which is a Otis A6164BP type. Should this relay be staying made up with no power applied to it and not wired? It feels like it magnetically being kept closed/energized once pressed in by hand.
Yes. That is a double wound coil, set/reset. More than two coil leads and all steel armature indicate this.
Core should have a groove around the top indicating a hardened core. Also on a set-reset relay, there is a small kickoff spring at the top edge of the armature.
PHP: 8.3.33 Page Time: 0.021s Queries: 21 (0.004s) Memory: 3.0046 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 19:15:41 UTC
