October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#29766 08/15/20 03:00 PM
Does anyone know of a compatible chip that isn’t obsolete and can be ordered to replace these?
[img]https://www.dropbox.com/s/ik7vq9d2gx72hxg/IMG_4768.jpg?dl=0[/img]
Hi, you should be able to replace the old TI chip with the ST one M48Z128Y-70PM1
Is the other one losing its parameters? Think they usually guarantee the lithium battery for around 10yrs but I’ve had them a lot older
Looking at the picture of your chip that’s a 2007 date code 13 yrs old
Ya, won’t hold parameters. We had one older one to get the car running but want to order some. That ST part number is coming up obsolete and non-stock too.
I use a Dallas Semiconductor Battery backed ram DS1245Y-70. They should be availiable. I use it in my eprom reader/burner also. I always save the files, even the battery ram. Saves headaches later on, I use a Dataman Programer.
Perfect, I will try those. Thanks Rolly.
Typical, the Dallas ones fine and Farnell show ST one not in either I keep quite few spares, and definitely copy the chips if you can, I always do, good luck
Dave
I do backup chips when I can but never got to this job. The route mechanic did have all the parameters backed up though. I used to use a higher end programmer but a few years ago tried a cheep Chinese one because it’s very small, like 2” x 3” x 3/4,” and USB powered. I love it and have been using it ever since. I’ve yet to find any chip it doesn’t work on and it’s fast. For anyone interested it’s the TL866ii Plus and you can get it on Amazon for $60.
I’ve got the very same one it’s great
IDWT,
Are all brands of the TL866ii Plus created equal? I see a few different brands on Amazon that come with different adapters. I have never burned eproms before and would like to learn how. Do you think all the extra adapters are necessary for our line of work?
That’s a good question and I’m not sure. I suspect they are. I wouldn’t spend extra money for the adapters for everything but some come with a couple different PLCC adapters. Those are the only ones I’ve used for elevators.
Which cpu board you using the CPU40 or the CPU561 that requires a kone sim card to load the board.software?
Ok, thanks buddy.
It’s an CPU40. It was in the pic, just upside down. Should that Dallas Ram chip work for either CPU?
This little Hermit Shell case fits the TL866ii perfectly (tight)
https://www.amazon.com/Hermitshell-20000mAh-Portable-Charger-External/dp/B01N2Y8WTJ
Or this one if you prefer a little color. It’s also about 1/8” thicker so not quite as tight
https://www.amazon.com/Hermitshell-Travel-Fujifilm-Smartphone-Printer/dp/B0825KZRM9
I also tried a Case Logic TBC-403 soft camera case. It’s a great fit too and you could probably stuff it into a tighter space if needed but maybe not as much protection as those firm-shell cases.
The Dallas Chip works for both, CPU40 and CPU561. I had to have a programmer that would program OTP Bipolar Proms like 74S188 open collector and tri state 74S288 Proms plus PAL chips. The expensive Dataman covered all.
What are those for?
They are used to direct Eproms to read certain area's or used on displays. The kone TMS 900 Memory board had 3 Bipolar proms and you have to have right programmed chip for version of software installed.
PHP: 8.3.35 Page Time: 0.057s Queries: 48 (0.013s) Memory: 3.0794 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 02:51:54 UTC
