#29821 08/26/20 11:48 PM
Elevator_Logic
Elevator_Logic
I have a TAC32 down with LCD reading 1920/1922 faults. This happened directly after storm power outage. The technican before replaced the IOD board and that did not fix the problem. I believe the Job Software needs to be reloaded. What is the procedure for doing that?
Check J16. It should be 18.
And you have to do an SPC after replacing the IOD. If J16 has changed to 0 and you did do an SPC after replacing the IOD, you will have to do another after changing J16 back to 18.
Elevator_Logic
Elevator_Logic
Okay I will confirm that
What is the procedure for reloading the job profile using the thumb drive in controller. I know it plugs into the main controller board and you then either hold a button down or select a option in the UIT.
PHP: 8.3.36 Page Time: 0.025s Queries: 20 (0.007s) Memory: 3.0046 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-04 20:35:40 UTC
