Elevator_Logic
Elevator_Logic
Hey brothers can anyone help me with the steps for reloading Tac32 job profile with the USB thumb drive? I believe you insert it and then hold a couple of the smaller black controller buttons down but can't remember any longer.
Thanks for any help
Press & hold RST & while holding down RST, press & hold UDLS, then let off RST, but keep holding UDLS until STAT light starts blinking slow, slow, fast, fast. Then let go of UDLS. Controller will reset when finished.
Elevator_Logic
Elevator_Logic
WLTR00 I love you
If there is a file in the backup folder it is probably adjusted and you are probably okay putting it in the update folder and loading it as described. If there is not and you are taking the file from the folder with the job number then you are most likely loading an un-adjusted job file making your problem much worse. As a rule, I will always rename the folder in backup and do another UDLS so you have the last backup and a new one. Then always use the most recent unless you have specific reason not to. You never know what may have been changed since that backup was made. But if you have a watchdog and the UIT is working I doubt there is anything wrong with the job file except maybe that 1 parameter that likes to change to 0
PHP: 8.3.36 Page Time: 0.025s Queries: 22 (0.006s) Memory: 3.0129 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 20:35:18 UTC
