0 members (), 24 guests, and 1 robot.
#30014 10/05/20 04:58 PM
Tac 32
CPU FPGA V1R4
IOD FPGA VERSION:0
BOOT V0R5
PLDBAD LED red, no SAFCPU OR SAFE LEDS
FAULTS ON START UP 1926,1925
So far I have done a spc programming with no luck. Thanks for any suggestions in trouble shooting. I'm leaning toward bad output from SAFECPU internal.
I Online: Content
What’s J16 set to?
Did you try a get command?
W Online: Content
Try GET command and then WRT & RST.
If not check J16 as Dirt suggested. Should be 18 if a Hydro.
Hey Kcmprize, what was the cause/solution to this? Having a similar issue. And could use a hand
L Online: Content
I had the same thing happening. It ended up being a defective toggle on the IOD for the car door bypass
PHP: 8.3.33 Page Time: 0.032s Queries: 26 (0.008s) Memory: 3.0180 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:36:21 UTC
