#30014 10/05/20 04:58 PM
Tac 32
CPU FPGA V1R4
IOD FPGA VERSION:0
BOOT V0R5
PLDBAD LED red, no SAFCPU OR SAFE LEDS
FAULTS ON START UP 1926,1925
So far I have done a spc programming with no luck. Thanks for any suggestions in trouble shooting. I'm leaning toward bad output from SAFECPU internal.
What’s J16 set to?
Did you try a get command?
Try GET command and then WRT & RST.
If not check J16 as Dirt suggested. Should be 18 if a Hydro.
Hey Kcmprize, what was the cause/solution to this? Having a similar issue. And could use a hand
I had the same thing happening. It ended up being a defective toggle on the IOD for the car door bypass
PHP: 8.3.36 Page Time: 0.035s Queries: 26 (0.010s) Memory: 3.0193 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 20:41:46 UTC
