1 members (Johnny),
Posts40,940
Posts: 2 |
I am having a problem with a Gen2 in that it drifts up a little before taking off. I tried lengthening the brake pick time but it doesn't seem to make any difference. I know it's saving ok because when I reset the power the change is still in there, but the car is still drifting. I have set the brake pic time out to 3000 or 3 seconds with no change in the issue. As soon as the door closes the car drifts up a little then runs down, you don't notice it in the up direction as much because it's going up anyway. Anyone else experiencing something similar? It's possible we are missing a step in the saving process but I would think if it still shows our changes after we cycle the power it was saved properly.
Posts: 132 |
Elevatrics
Elevatrics
Posts: 22 |
I am also experiencing same problem on one of the Otis gen2 comfort in my portfolio. And I know it has to do with the load as You have said @DripCan, how do we solve this problem? For someone who is new to Otis lifts
Posts: 82 |
Start with swapping out the load weighing sensors to see if that works. If t doesn’t, make sure the OAD Board is wired in.
Posts: 134 |
Depending on the age of the GeN2 and what kind of drive used....
OVF Drive -> ALWcomp Corr (Correction factor for internally calculated loadweighing compensation torque). Ultra/Global Drive -> Pretorque Trim (Pre-torque values to prevent rollback)
/Alex
Elevatrics
Elevatrics
Posts: 22 |
Need help with otis gen2 bringing up DRV: <speed, 36. R=39
Elevatrics
Elevatrics
Posts: 22 |
Speed Errors, clear (shift 5)
Elevatrics
Elevatrics
Posts: 22 |
