0 members (), 15 guests, and 2 robots.
#30156 11/12/20 10:06 PM
I am having a problem with a Gen2 in that it drifts up a little before taking off. I tried lengthening the brake pick time but it doesn't seem to make any difference. I know it's saving ok because when I reset the power the change is still in there, but the car is still drifting. I have set the brake pic time out to 3000 or 3 seconds with no change in the issue. As soon as the door closes the car drifts up a little then runs down, you don't notice it in the up direction as much because it's going up anyway. Anyone else experiencing something similar? It's possible we are missing a step in the saving process but I would think if it still shows our changes after we cycle the power it was saved properly.
Ron H #30158 11/13/20 11:20 PM
Load Weight
Ron H #30162 11/14/20 05:27 AM
O
Elevatrics
Elevatrics
O Offline
I am also experiencing same problem on one of the Otis gen2 comfort in my portfolio. And I know it has to do with the load as You have said @DripCan, how do we solve this problem? For someone who is new to Otis lifts
Ron H #30374 12/21/20 02:39 AM
Start with swapping out the load weighing sensors to see if that works. If t doesn’t, make sure the OAD Board is wired in.
Ron H #30375 12/21/20 07:50 AM
Depending on the age of the GeN2 and what kind of drive used....
OVF Drive -> ALWcomp Corr (Correction factor for internally calculated loadweighing compensation torque).
Ultra/Global Drive -> Pretorque Trim (Pre-torque values to prevent rollback)
/Alex
Ron H #33314 06/30/22 01:47 PM
O
Elevatrics
Elevatrics
O Offline
Need help with otis gen2 bringing up DRV: <speed, 36. R=39
Ron H #33315 06/30/22 01:49 PM
O
Elevatrics
Elevatrics
O Offline
Speed Errors, clear (shift 5)
NY Guy #34529 01/10/23 09:09 AM
O
Elevatrics
Elevatrics
O Offline
thanks
PHP: 8.3.36 Page Time: 0.034s Queries: 30 (0.008s) Memory: 3.0295 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-05 10:12:27 UTC
