10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#30452 01/08/21 10:14 PM
BRG
I have heard several horror stories about the I2 up leveling adjuster. I took a call on an old DMC that will not run up. The gauge port between the pump and the valve reads about 40psi when it's running. Looks like it is trying to run but the thing sits there. The coils are good as they are energizing but the thing sits there.
BRG #30453 01/08/21 10:18 PM
Chilling
Chilling
Does it run in inspection?
BRG #30454 01/08/21 11:10 PM
If the valve or MR is cold, you may need to run till it warms up. I have had that happen a number of times.
BRG #30456 01/09/21 01:00 AM
If that leveling adjuster screen is plugged up that's exactly what will happen. The screen is so fine your better off just replacing it, I wouldn't even try to clean it. All our guys carry a spare one in their trucks its such a common occurrence.
BRG #30457 01/09/21 04:16 AM
On this DMC, check for broken shunt wires on the TSL limit switch assy. If it’ll run up on INSP but won’t move up at all on auto, that’s classic TSL symptom.
True also is the clogged up leveler screen.
BRG #30458 01/09/21 04:30 PM
Definitely sounds like the screen is clogged. Do anything but tear the screen off! I hope that sounds as ridiculous to all of you as it is but you would be surprised how often I find a car with these symptoms and go to replace the part only to find someone has just ripped the screen off. Pretty much screwed at that point. Best just to keep them on the truck.
BRG #30459 01/09/21 05:17 PM
BRG
Thanks, I will check all of the possible causes mentioned. The machine room is quite warm so that one has been eliminated.
BRG #30462 01/10/21 01:04 AM
TC7 Offline
Also will reduce leveling speed if O Ring on up leveling adjuster is leaking
BRG #30465 01/10/21 04:20 PM
God point, with bad o-rings it can also turn itself out on its own until you have no up level speed. If you can turn it by hand the o-rings need to be replaced.
BRG #30472 01/11/21 04:56 PM
BRG
Turns out there were 2 broken wires and a broken contact. Thanks for the help, was not looking forward to pulling the pump and I learned a little about Dover equipment t.
BRG #30473 01/11/21 08:47 PM
That doesn't compute with the original post. If the coils were energized the car should move up; if it wasn't moving with energized coils, it indicates a valve issue. Cannot understand how the broken wires caused a hydraulic issue.
PHP: 8.3.37 Page Time: 0.051s Queries: 36 (0.016s) Memory: 3.0493 MB (Peak: 3.5943 MB) Data Comp: Off Server Time: 2026-11-25 02:20:54 UTC
