0 members (), 42 guests, and 2 robots.
#30480 01/13/21 02:56 PM
Was about to do a full load test on gen 2. Car was running normal. Put car on independent service and Put weights on car and it wouldn’t run. Took weights off the car and it ran to the top floor . It’s a two stop car. When it got to the top floor it shut down with Saftey chain open . And will not reset. It doesn’t seem to be the usual suspects as those inputs are active . The controller in hall station says car at floor 1. But it is at floor 2. Here is a list on the inputs in upper and lower case as indicated on service tool
2703 drive fault shutdown
safe2
safe
OS
GTC
PES
ICES
CSC
PIN
TCI
NORM
aud
bak
tak
mup
mdo
rn3c
ADS
FDS
BDS
TDS
AGS
FGS
LVL1
DZ
LVL2
NTB
ntt
ET1
ET2
et3
et4
PR1
PR2
PRUP
PRSC
odz1
odz2
ucm
dbd1
DBD2
cchk
BTNR
bten
HTSD
30V
mrst
cbp
1bp
art
arb
SPED
spsc
bf
PVOK
spdt
solf
iofl
acof
dcif
dcof
FC1
fc2
fc4
fc8
fc16
fc32
fc64
f128
The indicator in the car says 2. But I thought I remembered the car floor screen in door jam said 01.. fault log in drive says no saf mcss
Does anybody know what else is in the Saftey chain that could cause this ?
So my Saftey circuit is all made but safe and safe 2 are still not active. I have done a power on reset with service tool but something still holding it out . Is there another reset I’m missing ?
Try a hard reset from the inspection panel
CES. controller stop switch was bad. That was the problem. CES was not listed in my inputs on the service tool. I don’t know why. Only PES and ICES. that is the 2nd stop switch I had to replace on brand new gen 2s.
Just saw your posts, don’t spend much time on the BB, but if you need more O info send me a PM or email. ( new to the pm format)
You need pass codes to perform Gen 2 ...( underslung) Cat 5 tests,
PHP: 8.3.33 Page Time: 0.025s Queries: 30 (0.005s) Memory: 3.0305 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 08:31:41 UTC
