Topics7,432
Posts41,135
Members10,097
Posts: 778 |
First time working on one of these newer Kone phones on the car top. I’m getting a Lon fail red light and a PSTN fail red light. When I unplug the telco line and plug back in the red tail lights go off but come back after a minute or so . Shoukd I replace the board ? My line is good
Posts: 71 |
It may be a bad RIF board. Also keep in mind that problems like these arise if customers switch to VOIP over traditional analog phones line. Only KONE can program this board. I think there are instructions floating around for converting to another phone if you work for another company. However if you do work for Kone , Technical Support can call in to check programming.
PSTN Fail means low phone line voltage or no active phone line.
Elevator Guy
Elevator Guy
Posts: 22 |
Just an FYI kone will reprogram the phones one time for customer There is a DTMF config. But good luck
Posts: 778 |
My line is definitely good .. the lon fail red light is the first to come on .. so if I replace the board I will not be able to program it ? Only Kone ?
Posts: 120 |
Pstn, no phone line or broken phone line. Check phone voltage at ccbn board
Posts: 778 |
I can plug my telco line on top of car into tester phone and it Works perfectly
Posts: 108 Likes: 1
Posts: 108 Likes: 1 |
Jluff I have programming instructions if your interested.
Posts: 778 |
Ok thanks. I will DM you.
Posts: 778 |
I don’t see the lon fail red light in the manual . Does any one know what that indicates ? And does any one think replacing the board could solve this problem. It is voip phone line. However it worked for a few months with this phone line system. The only issue was the volume was hard to hear. But it worked
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
It seems like there’s always a red light on on those, don’t remember which but they work anyway. I have a procedure that tests the test way communication if you want it
Posts: 108 Likes: 1
VOIP lines require an adapter from the VOIP provider. Line voltage is too low to operate correctly. VOIP provider should have asked the building about elevator phone lines.
Posts: 778 |
The phone provider already has a booster hooked up to the line .. they replaced the booster and still getting pstn red light . Is there any specific specs for proper line voltage to these phones ?
Posts: 4 |
Would appreciate a copy of those instructions also. [email protected]
Posts: 7 |
Is there anyway to get a copy of those kone phone programming instructions thanks
Posts: 108 Likes: 1
Sorry, haven't been in the forum in a while. Give me your email if you would like the Kone phone instructions.
Posts: 523 Likes: 2
Posts: 523 Likes: 2 |
Posts: 19 |
Can you send me the reprogramming instructions
Posts: 19 |
Does anyone have the wiring diagram/cut sheet for the phone /video system
GT8767
GT8767
Posts: 1 |
Would you happen to know where I can get those instructions on replacing the phone with a different manufacturer?
Posts: 5 |
I’d also like those instructions! I work for a small independent company out of local 4 and we’ve been getting a lot more Kone cars. They allow 1 phone change after we get the account, but after that it’s nearly impossible. [email protected]
