10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#30656 02/25/21 02:02 PM
First time working on one of these newer Kone phones on the car top. I’m getting a Lon fail red light and a PSTN fail red light. When I unplug the telco line and plug back in the red tail lights go off but come back after a minute or so . Shoukd I replace the board ? My line is good
Jluff #30666 02/27/21 03:47 AM
TC7 Offline
It may be a bad RIF board. Also keep in mind that problems like these arise if customers switch to VOIP over traditional analog phones line. Only KONE can program this board. I think there are instructions floating around for converting to another phone if you work for another company. However if you do work for Kone , Technical Support can call in to check programming.
PSTN Fail means low phone line voltage or no active phone line.
Jluff #30677 02/28/21 04:54 AM
Elevator Guy
Elevator Guy
Just an FYI kone will reprogram the phones one time for customer
There is a DTMF config. But good luck
Jluff #30686 03/02/21 02:19 PM
My line is definitely good .. the lon fail red light is the first to come on .. so if I replace the board I will not be able to program it ? Only Kone ?
Jluff #30697 03/03/21 12:56 AM
Pstn, no phone line or broken phone line.
Check phone voltage at ccbn board
Jluff #30698 03/03/21 12:41 PM
I can plug my telco line on top of car into tester phone and it Works perfectly
Jluff #30700 03/04/21 12:39 AM
Jluff I have programming instructions if your interested.
Jluff #30701 03/04/21 12:23 PM
Ok thanks. I will DM you.
Jluff #30702 03/04/21 12:45 PM
I don’t see the lon fail red light in the manual . Does any one know what that indicates ? And does any one think replacing the board could solve this problem. It is voip phone line. However it worked for a few months with this phone line system. The only issue was the volume was hard to hear. But it worked
Jluff #30706 03/05/21 12:29 AM
It seems like there’s always a red light on on those, don’t remember which but they work anyway. I have a procedure that tests the test way communication if you want it
Jluff #30707 03/05/21 12:30 AM
VOIP lines require an adapter from the VOIP provider. Line voltage is too low to operate correctly. VOIP provider should have asked the building about elevator phone lines.
Jluff #30717 03/05/21 05:01 PM
The phone provider already has a booster hooked up to the line .. they replaced the booster and still getting pstn red light . Is there any specific specs for proper line voltage to these phones ?
Would appreciate a copy of those instructions also. [email protected]
Jluff #40328 11/06/25 04:15 PM
Is there anyway to get a copy of those kone phone programming instructions thanks
Jluff #40334 11/08/25 01:19 PM
Sorry, haven't been in the forum in a while. Give me your email if you would like the Kone phone instructions.
Can you send me the reprogramming instructions
Jluff #40724 02/24/26 04:42 PM
Does anyone have the wiring diagram/cut sheet for the phone /video system
TC7 #40979 04/14/26 12:48 AM
GT8767
GT8767
Would you happen to know where I can get those instructions on replacing the phone with a different manufacturer?
Jluff #41029 04/22/26 09:22 PM
I’d also like those instructions! I work for a small independent company out of local 4 and we’ve been getting a lot more Kone cars. They allow 1 phone change after we get the account, but after that it’s nearly impossible. [email protected]
PHP: 8.3.37 Page Time: 0.045s Queries: 54 (0.017s) Memory: 3.0967 MB (Peak: 3.5946 MB) Data Comp: Off Server Time: 2026-11-25 02:00:40 UTC
