wiz
Greetings
I am using cadi 3.1 on a smart mrl 002. When I connect my r232 to usb I get an error message
Connection to controller failed.
Does anyone know the comm port configuration in the laptop for comm port 1. It is currently set up for IMS. Baud rate 9600 data bits 8 parity none stop bits 1 flow control none. The port works with IMS. It is not with CADI. I may need to change the settings for the comm port. Thanks
Are you using a null modem adapter?
wiz
Greetings
No, I am using a CableCreation 3.3 Feet USB to RS232 Serial Cable with Prolific PL2303 Chip, DB9 Adapter for Windows xp.
Cheers
Originally Posted by wiz
Greetings
Cheers
You have to use a null modem adapter.
wiz
Greetings
Thanks for the input. Will use null modem adapter?
Bless
PHP: 8.3.33 Page Time: 0.022s Queries: 24 (0.007s) Memory: 3.0148 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 18:26:32 UTC
