0 members (), 15 guests, and 2 robots.
#31191 05/29/21 02:54 PM
Hello all,
I have a residential Garaventa Elvoron MR elevator and the position indicator on the COP is reading a question mark. I have tried changing the PI and I have also tried to reset the encoder positioning. Does anyone have any ideas what to do with this?
A little info on Garaventa they will not talk to you unless you are a dealer and they are referring me to the local dealer here. I have reached out to them several times and never get a response. If anyone has a place to start I would really appreciate the help.
ive had similar issues with garaventa as far as tech support and the only way around it is to get in touch with a field guy... do you know any garaventa guys locally? thats your best bet unless someone here has dealt with this issue... i dont have much experience with the Elvoron so im not much help there but definitely ask around to see if you can get in contact with a field guy, theyre usually helpful at least they have been for us in the past
What city and/or country are you in? Do you have wiring diagrams/schematics??
Yes I have schematics. Phoenix Arizona.
PM me, I think I can help
Hi I am having the same issue that cop displays question mark , been told plc needs to be replace , any ideas, thanks.
Check a couple things on the board:
Check PLC-board SW201 (should be on).
PLC SW202 should be off
You don’t need a new board
This is a Garaventa CPL and has a direct logic06 PLC not sure what switches you are talking about ? anyone has seen this issue on these units?
Have you resolved your issues with this unit?
PHP: 8.3.36 Page Time: 0.055s Queries: 34 (0.036s) Memory: 3.0434 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 10:44:28 UTC
