#31282 06/18/21 01:14 AM
Scrapwood99
Scrapwood99
looking for prints or any info on this controller its hydro submersible 4 stop think it composite .thanks in advance this link should show pics. [] https://photos.app.goo.gl/nRTfK5ZyyxytMs6V7
That is a four stop solid state card rack controller. Are you an owner, or a mechanic??? Why do you want prints?? What city are you in??
Scrapwood99
Scrapwood99
Mechanic ,job is Philadelphia suburbs car goes out on low oil occasionally relays have been replaced all cards also replaced .low oil timer adjusted all the way out .is there any way to extend that time, other than the pot?
You might have a valve problem.
Scrapwood99
Scrapwood99
Think they have replaced valve not sure if adjusted correctly have to look into that also tac the car next te there. Just wondering when u order the solid state boards are they job specific could I have the wrong board for this configuration is there difference between say a 2 stop to a 4 stop on the timer for each of these controls
Cards are not job specific. There are three slot and four slot cards. Higher number of slots will replace lower number of slots, i.e. a four slot board will replace a two or three slot board of the same type. If you have an I-2 valve, make sure the screen in the leveling adjustment id clean.
Scrapwood99
Scrapwood99
So the timer pot on the power board there was about 1/8 turn left ,increased that an so far car still running but no more adjustment left.also customer has a oil burner heater in room maybe may still have problems as the weather changes and that thing fires up not sure. But thanks for your help on this johnny
Usually, Dovers of that era had a bimetal sensor or some type of thermostat in the tank. when the oil got cold the thermostat would call for heat and the pump motor would turn on and run on bypass till the oil heated up. Those Dover valves would not move the car if the oil was cold, they would run till the oil got warm enough or the Low Oil Timer tripped. I would check the thermostat before replacing anything.
Scrapwood99
Scrapwood99
This tank has been replaced years ago I know the thermostats your taking about hi and low
think they were just removed so far the car has been running good thx for the help
PHP: 8.3.33 Page Time: 0.107s Queries: 32 (0.077s) Memory: 3.0355 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:26:28 UTC
