0 members (), 23 guests, and 3 robots.
#31375 07/09/21 05:31 PM
Hi, so I have a Kone with a couple faults that I cannot find info on. First one is 0268 and the second is 120-2039. I'm hopeful that someone may know. Thank you
Hi Matvator
Check you main contactor ore replace them
01 20 - 20 39
Error on feedback from main contactor below
driving.
The monitoring of the main contactor
the relay has detected that the contact is in
wrong position while driving.
Main contactor relay contact
is monitored while driving.
02 68
Main contactor in drive fails to pick but start permit does change
"Main contactor and Start permit input picked and dropped for 3 times(Default vaule in S-test ID 538) but elevator does not run.
Note: Value can be changed in S-test id 538"
Thanks Jadam for the info, this is a out of town job so I'll make sure I have those contactors.
PHP: 8.3.33 Page Time: 0.024s Queries: 20 (0.006s) Memory: 3.0035 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 18:18:05 UTC
