robot. |
Posts40,945
Posts: 118 |
I have a 2 car bank 3 stops I had a problem with car 1 phase 2 wasn’t working correctly as soon as a call was pushed the doors close completely even if you let your finger off the call button. Also the hold function doesn’t work you can still drive the car with it keyed to hold. I thought I had a bad phase 2 switch but everything meters out ok. I discovered this car was set to NY fire service adj 27= 003 and the other car that works correctly is set to mass adj27=001. The issue I now have is when I set car 1 to mass fire service phase 2 works correctly but the car will not reset off of phase 1. If I set adj27 to any other option but 1 it will reset off of phase 1 but phase 2 won’t function correctly. Has anyone ever run into anything like this?
