#31505 07/29/21 02:28 AM
ELEVATOR TECH
ELEVATOR TECH
I have a Schindler 3300. The LU sensor was broken. after replace that the CPU give me error 4305 and i dont know how to make a reset to clear that error and I can't not use Cadi because the port Com 1 it's not 9 pins and only have 5 pines in line... any help would be appreciated
[img]http://[/img]
Go to menu 10 - Enter
Submenu 127 - Enter
Change the 0 to 1 and hit enter.
UCM fault should be cleared now!
/Alex
Alex75 #31508 07/29/21 02:35 PM
ELEVATOR TECH
ELEVATOR TECH
Thanks Alex75
I will do do that and i will let you know...
Thanks for your fast answers 🙏🙏👍👍👍
Engineer
Engineer
com1 port is not used for cadi..
ELEVATOR TECH
ELEVATOR TECH
I did that but the 4305 fault it's not clear and the controller have the red error light on
BRG Offline
To reset the unintended movement the car has to be on hoistway access then go to menu 10 press enter go to 127 press enter make it a 1 and press enter. Some of the newer ones have a switch under the door bypass switches that can be slide in one direction to simulate hoistway access. Be sure to switch it back.
Release elevator from blocked state by dedicated reset of
the tripped safety device.
To reset ucm fault
Hit enter
Number 10 will appear
Hit enter again, it will change to 101
Hit Up to change the 0 to 1
Hit enter
Reset SCPU
-:Car door safety contact opens at start
-:Verify the correct function of KTC, adjust KTC
accordingly.
Verify the correct installation of the doors and resolve any
issue found.
ELEVATOR TECH
ELEVATOR TECH
Thanks to the whole family for taking the time to help me.
The elevator it is working good 🙏🙏🙏👍👍👍
PHP: 8.3.33 Page Time: 0.025s Queries: 32 (0.008s) Memory: 3.0326 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 05:23:54 UTC
