#31556 08/12/21 06:26 PM
I have a tac 32 hydro that is constantly releveling. the seals on the jack are good...don't know where to go from here any suggestions? The unit is not even 2 years old
Txelevatorman #31557 08/12/21 08:14 PM
Did you do a standing test ?
Txelevatorman #31558 08/13/21 04:18 AM
Is manual lowering tight?
Txelevatorman #31559 08/13/21 11:07 AM
If it has telescopic jacks, can you see the upper or middle plunger slowly collapsing into the lower plunger while the elevator should be at rest?
Txelevatorman #31560 08/13/21 11:10 AM
Go to lindenelevator.com and watch video on I2 leak downs
Jcjphoenix #31563 08/13/21 06:00 PM
2nd that, their videos are excellent. With an I2, my money would be on the lowering or check valve seats. These valves are super easy to pull apart and inspect but not much you can do if the seat is damaged. Then even if there isn’t anything visible, something may not be machined true. In some really old I2 manuals they talk about lapping these seats by hand on site but I’ve never gone that far. We typically just replace the valve if one of the piston seats are suspected.
Txelevatorman #31566 08/15/21 03:04 AM
Just had one that had a leaky muffler in the tank. After muffler replacement, all is well. cap off between the muffler and the valve. If it still leaks, it''s the muffler. Assuming you have done shutdown test.
Txelevatorman #31567 08/16/21 12:55 AM
The up leveling strainer, if not seated properly, will cause this.
Txelevatorman #31832 09/28/21 12:30 AM
THE releveling is in first floor ? if yes maybe you need adjust low pressure adjustment
djenergy #31838 09/29/21 03:05 PM
how do you know the seals are good? is it teloscopic jacks? or single stage?
also do this
power off with car level at floor
wait 10min and see how far the car drifts down (record this measurment)
Restore power level up car
repeate but this time hit the shut off valve in the motor room
wait 10 min
this will tell you if its leaking through the valve or the piston
KSNY #32037 11/03/21 05:37 PM
also do this
wait 10 min
Hes right, but be mindful also of oil contraction/expansion from temperature. if the cars been running alot and the oil is nice and hot the contraction as it cools will make it look like it's leaking down, even if it's not actually leaking.
PHP: 8.3.33 Page Time: 0.029s Queries: 36 (0.007s) Memory: 3.0472 MB (Peak: 3.5910 MB) Data Comp: Off Server Time: 2026-09-21 06:07:57 UTC
