Posts: 27 |
Can anyone tell me where I can get a full set faults and descriptions. The book I have is incomplete goes to 99 then skips to 140 and stops at 213. I keep getting at 109 and247 fault thanks
Engineer
Engineer
Posts: 281 |
02 47= Supervision for telephone line communication.monitors the dedicated telephone line medium which is provided for Emergency communications The dedicated telephone line medium which is provided for Emergency communications is not OK
Visual Alarm: HASG11: Output XFA6 Audible Alarm: HASG11: Output XFA5
To fix= Disconnect telephone line connected in KRM board.
Engineer
Engineer
Posts: 281 |
0109= Drive position lost.
Drive has lost position Drive count differs more than 300 mm at 30 or B30 vane edge Synchronisation drive request Check the position of 77:U/N and 61:U/N magnets. Move lift when power is off 01 09 38 08 DL Position lost LCEDRV bar pulse position is incorrect Bar pulse count differs more than 100 mm at 30 or B30 vane edge Synchronisation drive request Pulse position is recocered at 77 switch edge Move lift when power off.
Posts: 27 |
Thanks so much!!! Any idea where I can get a copy of all the faults?
Posts: 96 |
The faults in the range of 109s are drive specific faults you would need to identify the drive you're working on they won't always be the same faults and the subcodes would be different.
