#31689 09/03/21 03:06 PM
Scr
Scr
Hello everyone. Just replaced old HPV 900 drive with a new HPV 900 series 2 drive. Set the drive up per manual for closed loop system motor data is entered correctly speed of car etc. When I try to run on inspection brake picks but motor does not turn im reading 50v ac from the leads going to the motor from the drive. Is there a setting I’m missing? Any help is appreciated
Local 84 #31705 09/06/21 10:28 PM
The new inputs are on different terminals check to be sure those are correct for the new configuration. Check the encoder as well I replaced these drives on a swift and the plug had to be removed and repinned. You can check the speed command as well on the drive and compare to the swift command as a start.
Local 84 #31733 09/10/21 11:16 AM
Did you do an "Auto-Tune"? If not that will need to be done first. The procedure should be in the book that came with the drive.
Local 84 #31744 09/13/21 07:52 PM
Sounds like as said above your inputs are probably misconfigured. Sounds like your commanding drive on but not a direction.
PHP: 8.3.36 Page Time: 0.043s Queries: 22 (0.011s) Memory: 3.0123 MB (Peak: 3.5928 MB) Data Comp: Off Server Time: 2026-11-05 17:05:05 UTC
