Posts: 65 |
I have a 2 car bank we just took over. Tested fireman’s one car worked perfectly the other car won’t reset. Plugged in for ims and I show no reset input for this car I was able to force inputs on working car to sim phase - and two and reset accordingly but car one has no reset input and will not reset with key switch. Any ideas are appreciated I’m at a point where I’m going to reload job from usb on the uit
Posts: 65 |
Also according to inputs fsx is high I tried pulling wires for fsx cause prints show normally open also tried forcing input low in ims when I force it low it drops safety circuit and gives a blown fuse fault I checked fuse and it’s fine also slightly confused on that as it would makes sense car won’t come off cause fsx is alternate floor smokes
Posts: 1,766 Likes: 11
Posts: 1,766 Likes: 11 |
Something really not right there… Have you re-loaded in IMS for this car? Sounds like you’re looking at the last car you worked on’s IO map.
Posts: 65 |
Yeah reloaded a few times. Honestly think it was the previous company trying to mess with us. Ended up reloaded the usb to the cpua and then reloaded ims again got all my inputs and injected the I/o to get it off cars been running fine since yesterday
