Engineer
Engineer
Having trouble on this Kone Monospace, every 3 to 4 days it breaks down with these 3 errors, everytime when traveling down from top floor to bottom floor. (Only a 2 stop)
0101
0125
0026
Also I did notice a 0110 fault appear on one occasion...
I have bumped up the 6.40 parameter up from 2.5 to 3.0, which increases the max torque threshold, and I admit it has possibly lowered the chance of the fault happening, but after testing for roughly and hour, the lift stopped mid shaft with same faults.
Now the fault codes show that there's drive issues, but I'm trying to work out of it's a possible faulty 201:2 or 201:1 contactor, or faulty 460 contactor.
If anyone has had this issue before, and knows any deeper cause, I would love some help on it!
How old is it?
Engineer
Engineer
Roughly 13 years old, used heavily as it's in a retail store open 7 days
Engineer
Engineer
Also it is a V3F25 drive
Engineer
Engineer
Parameter 6_9 = 4.773
I think it's quite high?
0125 Is the weight adjusted correctly 50% and 0%?
0026 Is there a subcode? If it is the old tarco model it may need to be cleaned
I have the same problem
Engineer
Engineer
I have increased parameter 6_40 to 3.0, and have not had a fault for 9 days so far, maybe that fixed it
problem solved?
Troubleshoot to KONE elevator is fun.
Engineer
Engineer
I would say problem solved, I did clean out and use different contacts on all the main drive contactors. The problem has gone away.
I would say it was an issue with a bad auxiliary contact on one of the drive contactors
yeah it would be, cause i face same issue in kdl32 fault was 0023 as it says about car door contact i did a lot of test in all cards but issue did not resolve until i replace contactors 201:3
PHP: 8.3.33 Page Time: 0.083s Queries: 36 (0.043s) Memory: 3.0460 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 05:22:55 UTC
