#32066 11/06/21 03:35 PM
I was trying a learn run on a gen2 and I get a ntb len error at the bottom. Tool says to add 0746 (mm) to the length of vane. If this is a parameter change I can’t find it anywhere on the tool. If it’s telling me I need to make the length of the vane that rides with the car physically longer than why was the elev ever able to do a learn run in the first place?
Jcjphoenix #32109 11/15/21 02:16 AM
Jump out your normal limits while doing learn run
Jcjphoenix #32173 12/03/21 07:10 PM
It is telling you that the NTB vane length is incorrect. When entering the learn it will tell you estimated vane length for NTT and NTB and is dependent on Accel/Decel rate. If NTB signal is lost to early it reports the difference (746mm). Possibly the accel/decel rate parameter changed or you are losing NTB signal to early.
Jcjphoenix #32174 12/03/21 09:47 PM
It turned out to be bad leveling sensors causing the issue
PHP: 8.3.36 Page Time: 0.029s Queries: 22 (0.010s) Memory: 3.0120 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 19:53:48 UTC
