1 members (ot1989),
33
Posts: 239 |
I was trying a learn run on a gen2 and I get a ntb len error at the bottom. Tool says to add 0746 (mm) to the length of vane. If this is a parameter change I can’t find it anywhere on the tool. If it’s telling me I need to make the length of the vane that rides with the car physically longer than why was the elev ever able to do a learn run in the first place?
Posts: 69 |
Jump out your normal limits while doing learn run
Posts: 3 |
It is telling you that the NTB vane length is incorrect. When entering the learn it will tell you estimated vane length for NTT and NTB and is dependent on Accel/Decel rate. If NTB signal is lost to early it reports the difference (746mm). Possibly the accel/decel rate parameter changed or you are losing NTB signal to early.
Posts: 239 |
It turned out to be bad leveling sensors causing the issue
