#32150 11/29/21 03:26 PM
Hey all, having an issue with a TAC-32 and I'd like to see if anyone has seen this and can offer a better explanation.
Car shut down with a 1070 and a 1110 fault.
1070 fault says no LVU or LVD sensors
1110 is generic IO shutdown fault.
Have IMS, on the original call I found LVU sensor not working on the IO window. Sent Selector board to Access and they replaced the sensor. Got the board back, installed and same fault but now the LVU sensor is functioning correctly.
I can see LVU and LVD on IMS but the controller is not reacting to these inputs and throws the 1070 & 1110 pair when on automatic after leveling through a floor. Tested at both terminal floors (2 stop) but same issue regardless of car position.
Has anyone seen this issue? What was the resolution?
I'm confused about how the selector board is writing the input to the CAN network and the CPU is reading but not responding.
Bad CPU a possibility?
https://youtu.be/37fd1WvwGTA
Got a video of the car faulting out.
Do you have the backup software? I’d start by reloading software off that thumb drive.
I’ve had issues with can inputs from push buttons not working but after a software reload everything work fine.
This was the fix. Got board back last week and after a software upload the car ran normally.
Thanks for your help.
PHP: 8.3.33 Page Time: 0.023s Queries: 24 (0.004s) Memory: 3.0155 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 00:53:07 UTC
