0 registered members (), 16 guests, and 3 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#32207 - 12/10/21 07:54 PM oscillation at nominal speed
sampler Offline
sampler  Offline
dear colleagues, when I set the speed 1,60 ms on ACVF, car makes vertical oscillation. but on reduced speed (1,30) no oscillation .
Do you have any idea? Thank you.
Drive: ZA dyn 4C
synchronous motor
#32209 - 12/10/21 11:13 PM Re: oscillation at nominal speed [Re: sampler]
liftronic Offline
LA Elevator
liftronic  Offline
LA Elevator
US
Need to check the P-I-D parameters in your drive.
#32211 - 12/11/21 09:48 AM Re: oscillation at nominal speed [Re: liftronic]
sampler Offline
sampler  Offline
Thanks liftronic. These settings are for only open loop. So I can't change parameters. but there are some parameters. what do you think.
f_PWM Cycle frequency at parameter setting "M_PWM=Fix f_PWM"
SPD_KP Multiplication factor to modify the calculated basic amplification
SPD_TI Adjusting time Controller averaging time during the trip
#32212 - 12/11/21 03:01 PM Re: oscillation at nominal speed [Re: sampler]
Alex75 Offline
Alex75  Offline
Sweden
Adjust the SPD_KP parameter, also did you measured the weight of the counterweight and car? You have some parameters where you can enter these values.
Is it a ZA machine?
/Alex
#32213 - 12/11/21 04:18 PM Re: oscillation at nominal speed [Re: sampler]
liftronic Offline
LA Elevator
liftronic  Offline
LA Elevator
US
SPD_KP is the P gain in P-I-D and SPD_TI is related to ā€œIā€ in the PID controller. Those two parameters are the ones that you need to adjust. But be careful increase or decrease them in small steps.
#32214 - 12/11/21 04:45 PM Re: oscillation at nominal speed [Re: Alex75]
sampler Offline
sampler  Offline
Alex7, yes its a ZA (Sm200-20C). I didn't measure CW-car balance yet. If the parametres do not solve I'll do it. Installations are 3 years old. I replaced guide shoes. because older type was bad. now it is more
comfortable at 1,30 ms speed. After setting nominal speed this issue comes out.
Liftronic, when I set SPD_KP and SPD_TI, they effect starting of travel. For example motor makes noise if I increase SPD_KP. But car keeps on vertical oscillation on both direction.
#32215 - 12/13/21 01:41 PM Re: oscillation at nominal speed [Re: sampler]
john jay Offline
john jay  Offline
ohio
Many things can affect the ride quality. The parameters are the usual culprit but do not discount the encoders, velocity, and position, the hoist rope tension, the motor being out of tram, and the counterweight not at 50%.
#32216 - 12/13/21 01:46 PM Re: oscillation at nominal speed [Re: sampler]
john jay Offline
john jay  Offline
ohio
I would especially look at the velocity encoder and coupling, and of course, the encoder wiring should be shielded and separate from any other motor wires.
#32299 - 01/01/22 12:12 AM Re: oscillation at nominal speed [Re: sampler]
Turbo6 Offline
Turbo6  Offline
Chicago
Is this a new installation or existing?
#32301 - 01/01/22 08:14 AM Re: oscillation at nominal speed [Re: Turbo6]
sampler Offline
sampler  Offline
Exiting. 2 elevators are in same situation.
#32302 - 01/01/22 08:19 AM Re: oscillation at nominal speed [Re: sampler]
sampler Offline
sampler  Offline
we are going to replace ropes. Because ropes twist about 20 times at one trip. travel distance 65m.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.037s Queries: 15 (0.010s) Memory: 2.7295 MB (Peak: 2.9373 MB) Zlib disabled. Server Time: 2024-06-16 22:02:48 UTC
