#32217 12/14/21 07:31 PM
Does anyone know how I would get the fault codes for a Eco space with the KDL16 drive. I’m getting a 120 fault.
Did you get the sub code?
No I didn’t
Go to menu E. Sub menu 1 and hit enter. It then lists fault codes. Up and down to go through them. F1 is newest. On a fault code that has a subcode hit enter and it scrolls the subcode across the screen. Go back to menu E, sub menu 2 and hit enter, change value from 0 to 1 and hit enter again to clear all faults. Also note the status of everything as it was when the fault happened changes on the LEDS when you view the faults. So for instance if you wanted to know if you had a start permit or the status of the doors or something when a fault happened, the LEDS will show you how it was when it faulted.
Thank you that’s a lot of help! I still don’t have the fault codes for the drive. I have the faults up to 99 then start again at 144. Im wonder where I could find those. Or any drive information would be great!
The codes your missing aint in the normal fault code book. Theres a seperate little book of codes just for the drive. I have it, post back with the subcode I'll tell you what it means. Or PM me.
Had to reset it and it’s an out of town job so I don’t get there a lot. But I’ll get the sub codes for you next time. How does one get that handy little book of drive errors?
PHP: 8.3.36 Page Time: 0.024s Queries: 28 (0.007s) Memory: 3.0274 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 20:41:23 UTC
