#32495 02/06/22 09:21 PM
Tac 32 Evo Controller, traditional traction machine only runs for about .5 seconds and has an "Torque Limit Fault". Motor is only 2 years old car has been moded. Counter weight was added for addition of new weight.
Accord Drive 663 fault - XS_Torque_Limit - The torque current is greater than 2.5 times the motor nominal current for .5 seconds (if running elevator on Inspection or Automatic Operation.
Things I've done
- Motor Windings ohmed good (9 wire motor multi voltage, wired for high voltage)
- Brake is fully picking
- Safties are not dragging
- 35 amp motor rating, each leg on in-rush current is 28 amps or less.
- The car moves about an inch in each direction before it faults.
- Motor shaft spins 1 1/2 rotations before it faults.
- It has oil and was greased recently (from what I can see)
- They put in a flex coupler with new motor.
Planning to do
- I'm going to pick the brake and see if the car drifts to ultimately tell if it is mechanically bound at all.
- Try and find the parameter settings to increase the time or current to see if I can get it to pull through what ever it is preventing or causing issues as the machine may be seizing and I will get some feed back and noise to narrow in.
Personally I think this is a drive issue, but I need to finish preliminary testing.
My question to to everyone is, has anyone seen this fault and if so was it associated with the Accord drive? Before I go bonkers.
Thank you!
[img]https://gm1.ggpht.com/h1HPTLnR0QMZs...kuMckwjD74LaXQtIGt3escQ=s0-l75-ft-l75-ft[/img]
check the velocity encoder and the wiring.
Evo implies it’s an MRL with belts but sounds like it’s a geared machine. It does sound encoder related though and I would start by ringing out the encoder wires from your encoder, through the FWIA card, to both the drive and the IOE. These “Micro Mate-N-Lock” plugs on the FWIA card are very problematic for encoder signals.
O
O Offline
Have you tried to/or unsuccessfully tried an auto tune? Don't know about the evos but I had a lot of Tech 32 model my jobs turned over with incorrect data plates(on motor) and never ran right to begin with
TC7 Offline
Torque limit is indicator of bad motor encoder
PHP: 8.3.33 Page Time: 0.032s Queries: 24 (0.005s) Memory: 3.0182 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 01:50:57 UTC
