2 members (sampler, elevatorman1966), 24 guests, and 2 robots.
local 18(1988)
local 18(1988)
I can’t get de input to go high car won’t run!!!!!!
Some cars have a secondary gate switch. Check that I've seen that
Otherwise more info would be needed. Changed DE module? Pico fuse for the module
local 18(1988)
local 18(1988)
I’ve gone thru gates and limit switches all my inputs for door circuit are working good did hyperterminal PMI cards test all a go I’m finding my drive isn’t firing up there for no 24 v getting to some off my inputs got 125 v going to drive but nothing is turning on I’m running out of ideas my drive is magnetek dsd412 I’m thinking drive might be bad . Any help appreciated thanks Frank
It's possible the power supply is bad on the drive. The print should show where the 24v comes from
local 18(1988)
local 18(1988)
You are certainly correct me and my partner took drive apart and found bad power supply thankyou for the help buddy we will ordered new one today your awesome
MLO Offline
EECO
EECO
upndown frank, I have same issue. did you have the quantum drive? mine is ac and according to my books, its the quantum 10k.
I checked the 4 power supplies in the bottom right front and they all test good. did you find another power supply somewhere?
my next step is to do the low voltage test on the drive components. Caps, resistors etc.
local 18(1988)
local 18(1988)
My drive was dsd412 scr drive not quantum drive but are power supply was in the drive not sure about quantum
PHP: 8.3.36 Page Time: 0.034s Queries: 30 (0.008s) Memory: 3.0319 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 18:03:21 UTC
