#32506 02/09/22 07:28 PM
Having some issues with a tac20 that's about a 4hour drive 1 way.
2 stop unit
I can run on inspection fine.
If taken off inspection near the top floor it will level to top floor and will take the call to the bottom floor.
As it get to the bottom floor it levels then faults out with 1025 bp parity fault. It will not run again after this unless you take to top floor on inspection and repeat.
So far the leveling and BPP mag have been changed at the bottom floor using the template to ensure alignment and south (yellow side) facing out.
The selector has been changed and a new hoistway scan has been done and completed without error.
My next step was going to be reloading software but the thumb drive was not onsite.
Customer has alegitly found thumbdrive and im looking for any other suggestions before making the 4 hour 1 way trip to continue on
I'm using IMS
Thank you for any help
Well when you let the car level in to the 1st floor BPP should be high and BP1, BP2, BP4, & BP8 should be low in IMS. If that’s not true you need to use a meter to see why. All but the newest Tac20s use LON for the BP inputs so you’ll trace the signals through the CWID, in on con 403 and out to the LN card on Con 706. If you see the inputs correctly at the LN card with a meter but not in IMS you’ll need to see if you have a LON problem. Can you see the inputs correctly in LON Explorer or not. Could be a connection through the CWID or a bad LN card. Newer TAC20s bypassed LON and ran the BP inputs straight back to the 188E. With intermittent BP errors on these older cars making this change helps a lot. Oh and if you do see the BP inputs correctly in IMS but still get this fault make sure your directional limits and NTS inputs are in the right state.
PHP: 8.3.36 Page Time: 0.037s Queries: 18 (0.011s) Memory: 3.0001 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 20:09:25 UTC
