1 members (Elevator Fixer),
64
Posts41,073
Posts: 778 |
Hello. I’m getting a 1030 then a 1009 (Init SD down) Very intermittent. However I think I witnessed it once. It’s a 4 stop and it seems to happen at the top floor. The door opens. Then closes a few inches and the indicator goes blank and doors lose power. Then all of a sudden it comes back to life and doors close and it goes down.
1009 - valve contact error. (MCD open ) down run failure, valves or MC not ready. MCD inactive or MCE active during down run . Defective MCD input . Defective MCE input . Defective relays
1030- Leveling sequence error - Leveling inputs activated in an invalid sequence.
Any ideas Would be appreciated. Do I need lon cable to change input ports? Don’t have one I have old IMS
Posts: 270 Likes: 2
Posts: 270 Likes: 2 |
Have you tried replacing all the valve control and mcc relays?
Posts: 579 Likes: 6
Posts: 579 Likes: 6 |
Be sure the retainer clips are on all the relays. It's also worth noting the finder and schrack relays seem to have different thickness pins, can't remember which ones are thicker, but one relays will fit looser than the other. I went on an OT callback that the car was shutdown because one of the relays literally halfway fell out of its base, the mechanic had just swapped all the relays out and threw the retainer clips away.
Posts: 778 |
I did replace mcc relays. Then I ran out. Ordering more That’s interesting about the different relays. I don’t even know which ones I have .. I think there are clear schracks on bottom row then blue ones above.
Posts: 270 Likes: 2
The finder ones were trouble back in the day
Posts: 148 Likes: 1
Posts: 148 Likes: 1 |
The finder ones were trouble back in the day If i remember correctly the orignal Finder relays only had contacts that were rated for 6Amps. Now they are rated for 8 amps. This increased the life of the relay and made them more reliable
Posts: 778 |
This happened again .. took a few weeks. This time it was 1040 first then 1009. Lots of relays were changed few weeks ago. Seems to be people get trapped. But it’s always running wheh I arrive. Any ideas what to focus on ?
Posts: 778 |
If I have a bad MCE OR MCD input. How do I change them ?
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
I’m not sure how the 1009 could be related to the 1040. But for the 1009, it could be the starter logic board picking MUTS when it shouldn’t or there is supposed to be a certain suppressor on the MUTS relay. Should be the cylindrical thing in black heat shrink with black wires coming out. Not one of the plug in ones. The starters can bleed through quite a bit through up to speed and that relay will chatter and even fail to drop after a run.
Posts: 778 |
Txs dirt. Do you have a part number for the suppressor. Also noticed my main line comtactor is humming very loud
Posts: 778 |
Would a bigger starter help ?
Only if the one that’s in there is too small. The suppressor Print number is 381AF1. Should cross to a part number.
Posts: 778 |
How does the suppressor wire in to a plug in relay ?
Posts: 6 |
If 1030 was your first fault at the top of the hoistway check the magnets at the back of the tape , make sure that they are in the proper sequence
How does the suppressor wire in to a plug in relay ? You wire it across the coil
Posts: 778 |
1030 was the first fault once. Last time it was 1040 first I believe the magnets on back of tape on terminal landings need to be smooth with no gaps. I will check Monday
