1 members (BRUCE91),
Posts41,073
Posts: 778 |
Working on a Kone LCE with KDL16s drive module I’m getting a 0126 after reset . Car starts to move and faults out immediately. I have seen that code refer to door lock on one fault list I have. And a brake fault on another. Does anyone know what this fault definitely is referring to and what to look for ?
Posts: 778 |
Update on this. As soon as I put car on inspection I get a 0021 Saftey chain fault. But the Eaton 5p 850 battery unit is beeping low battery. This is most likely the problem I would think
Posts: 778 |
It’s not the ups. Changed 6-12 to 0. Won’t move on inspection or auto. Everything says ready then as soon as car gets drive up or down it faults F-1. 0026. Then eventually. 0106
Posts: 778 |
3075 sub code. I do not have this sub code on 0126.
Posts: 805 |
Have you checked the thermistor in the motor? I think it is run in the same cable as the machine stop switch. It will throw the same fault.
Posts: 778 |
I did not get to the top of shaft yet. The car is down low. Inspection faults out also so I can’t move the car. Safety led stays lit during fault .. it accepts a call and gets an drive up led lit. Then faults out. 0126 sub code 2. 0. 3075 .... I Will be back tomorrow
Posts: 778 |
After the 0126. A 0106 will pop up. Inverter not ok. Braking resistor damaged Check tachometer and thermal switch connections
My brake relays look good
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
The sub code 3075 is Brake control board (BCX) hardware specific failure feedback. The 2 is a BCX fault code saying relay/relays are stuck
The BCX board is internal to the drive and I don’t know if you can get it separately but there are 2 little pilot relays on it. I suspect it monitors the back contact on them and when the contact fails it assumes the relay is stuck. But that’s just a guess.
Posts: 778 |
Thanks dirt. So The entire drive needs to be replaced ?
Posts: 778 |
I will take out the drive tomorrow. Hopefully it can be repaired. I can imagine the price is very high to get new from Kone
Posts: 778 |
I should probably replace the brake control module also
Posts: 81 |
Hi Jluff, if needed I can have that drive rebuilt for you.
I sent you an email
Posts: 82 |
0126 (3075) is your Brake control Board, more than likely the Relays, they can be changed separately, I’ve done quite a few, it’s a pain to do on the 16s tho, good luck 👍
Posts: 778 |
The brake control board is internal in the drive ? Or it’s part of the brake control module on side of controller. Silver box ?
Posts: 778 |
Oh. I thought the bcx (brake control board ) was part of the KDL 16s drive. Where is this module located. In the silver brake module unit on side of controller?
Posts: 82 |
That’s a brake control relay from a V3F16es The KDL16s brake board is inside the drive
Posts: 778 |
The brake board was bad inside of drive... Repair shop fixed it and car is working. I did have to replace my car top 12v battery though. Next time have to disconnect it when power is off ..
Posts: 522 Likes: 2
Posts: 522 Likes: 2 |
What repair shop did you send it to?
