0 members (), 115 guests, and 2 robots.
Posts41,073
Page 1 of 2 1 2
#32868 04/06/22 10:55 AM
Working on a Kone LCE with KDL16s drive module
I’m getting a 0126 after reset . Car starts to move and faults out immediately. I have seen that code refer to door lock on one fault list I have. And a brake fault on another. Does anyone know what this fault definitely is referring to and what to look for ?
Jluff #32869 04/06/22 12:59 PM
Update on this. As soon as I put car on inspection I get a 0021 Saftey chain fault. But the Eaton 5p 850 battery unit is beeping low battery. This is most likely the problem I would think
Jluff #32873 04/06/22 05:07 PM
It’s not the ups. Changed 6-12 to 0. Won’t move on inspection or auto. Everything says ready then as soon as car gets drive up or down it faults F-1. 0026. Then eventually. 0106
Jluff #32874 04/06/22 05:31 PM
3075 sub code. I do not have this sub code on 0126.
Jluff #32875 04/06/22 05:40 PM
Have you checked the thermistor in the motor? I think it is run in the same cable as the machine stop switch. It will throw the same fault.
Jluff #32876 04/06/22 06:24 PM
I did not get to the top of shaft yet. The car is down low. Inspection faults out also so I can’t move the car. Safety led stays lit during fault .. it accepts a call and gets an drive up led lit. Then faults out. 0126 sub code 2. 0. 3075 .... I Will be back tomorrow
Jluff #32878 04/06/22 06:59 PM
After the 0126. A 0106 will pop up. Inverter not ok. Braking resistor damaged Check tachometer and thermal switch connections
My brake relays look good
Jluff #32882 04/06/22 10:59 PM
The sub code 3075 is Brake control board (BCX) hardware specific failure feedback. The 2 is a BCX fault code saying relay/relays are stuck
Jluff #32883 04/06/22 11:09 PM
The BCX board is internal to the drive and I don’t know if you can get it separately but there are 2 little pilot relays on it. I suspect it monitors the back contact on them and when the contact fails it assumes the relay is stuck. But that’s just a guess.
Jluff #32885 04/06/22 11:28 PM
Thanks dirt. So The entire drive needs to be replaced ?
Jluff #32887 04/06/22 11:57 PM
I will take out the drive tomorrow. Hopefully it can be repaired. I can imagine the price is very high to get new from Kone
Jluff #32890 04/07/22 12:55 AM
I should probably replace the brake control module also
Jluff #32892 04/07/22 03:35 AM
Hi Jluff, if needed I can have that drive rebuilt for you.
I sent you an email
Jluff #32893 04/07/22 12:45 PM
0126 (3075) is your Brake control Board, more than likely the Relays, they can be changed separately, I’ve done quite a few, it’s a pain to do on the 16s tho, good luck 👍
Jluff #32894 04/07/22 01:15 PM
The brake control board is internal in the drive ? Or it’s part of the brake control module on side of controller. Silver box ?
Jluff #32896 04/07/22 02:05 PM
Engineer
Engineer
The brake control module is seperate from the drive,
https://www.zjelevatortravelingcable.com/sale-kone-elevator-spare-parts-56362988.html
Most likely bad relays. Probably cheaper just to get an entirely new brake control module.
Jluff #32897 04/07/22 02:18 PM
Oh. I thought the bcx (brake control board ) was part of the KDL 16s drive. Where is this module located. In the silver brake module unit on side of controller?
heisenberg #32898 04/07/22 03:09 PM
That’s a brake control relay from a V3F16es
The KDL16s brake board is inside the drive
Jluff #32991 04/18/22 01:36 PM
The brake board was bad inside of drive... Repair shop fixed it and car is working. I did have to replace my car top 12v battery though. Next time have to disconnect it when power is off ..
Jluff #32996 04/18/22 08:15 PM
What repair shop did you send it to?
Page 1 of 2 1 2
PHP: 8.3.36 Page Time: 0.045s Queries: 55 (0.015s) Memory: 3.1141 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-07 02:19:29 UTC
