October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#32950 04/14/22 06:44 PM
Have any of yall replaced the inverted jacks from Schindler with a traditional hole less 2 stage jack? If so what manufacturer did you go with? I have a job with major pitting on the jacks and we would love to get away from the DL Martin inverted jacks if at all possible.
Goat #32953 04/15/22 02:22 PM
Your choices really are limited to EECO and ITI, however you are much better off taking the jacks out, have them resurfaced at a hydraulic cylinder shop and reinstall. Schindler's sling is just 10 ga. galvanized, so you need to build and entire second sling to lift from, as the new jacks will have a pickup point above the cab, where the Schindler sling has a pickup point at the bottom of the car. This in turn now will most likely require more HP, which requires a new motor starter and most likely disconnect and feeders. Oillift stopped selling the GMV jacks, which we have used in the past for jobs like this, they had the smallest heads, so were the better option.
PHP: 8.3.35 Page Time: 0.048s Queries: 18 (0.009s) Memory: 2.9982 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-10-11 02:51:33 UTC
