#32955 04/15/22 03:01 PM
Having an issue with hso, I adjusted all the cams even went off another door operator. According to the board my sequence is fine sso,hso,mso,fso,dol. According to my handheld tool hso is never coming in and the sequence on the handheld appears to be fso mso fso dol. So currently I have fso acting as hso. Anyone ever encounter this? On the waiting list from gal just figured I'd throw it out there.
Kyled92 #32969 04/16/22 11:00 PM
Bad board
Kyled92 #32973 04/17/22 03:10 PM
Make sure your close sequence is also correct, this will also cause this
Kyled92 #32986 04/18/22 02:24 AM
I would swap the board with the one in the other operator you mentioned. That will tell you if the boards good immediately. The parameters on this operator are stored in the drive and you can pull the board without touching the cams. Should be pretty quick to do.
PHP: 8.3.36 Page Time: 0.105s Queries: 22 (0.054s) Memory: 3.0116 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 21:30:47 UTC
