#33035 05/03/22 03:04 PM
Elevator_Logic
Elevator_Logic
Hey guys,
I have a Otis 211 part of a duplex. The "quick close" feature isn't working. I mean to say when you hit door close or hit a call it doesn't bypass the door close timer and close the doors. Is there any way to adjust this or turn it on?
Elevator_Logic #33037 05/03/22 04:51 PM
As far as I know there no way to bypass the door close timer. You can try shortening it and the hall call dwell time?
Elevator_Logic #33040 05/04/22 12:21 AM
I haven't adjusted that on a 211 but hitting the door close button should put the controller into short door time. It should be a seperate adjustment from the standard car or hall close time. Most of my cars I keep the close times in the 5-7 second range and the shortened door time at .1 seconds.
Elevator_Logic #33054 05/06/22 10:50 PM
On a 211 you have to choose between the car call or the close button short timing the doors, or neither. EN-CK parameter, 0 = neither, 1 = car call, 2 = close button. But it won’t shorten the door time below the ADA door time parameter ADA-T.
Indirtwetrust #33055 05/07/22 12:11 AM
Elevator_Logic
Elevator_Logic
Thanks a lot I appreciate it
PHP: 8.3.33 Page Time: 0.028s Queries: 24 (0.007s) Memory: 3.0146 MB (Peak: 3.5918 MB) Data Comp: Off Server Time: 2026-09-21 00:48:49 UTC
