Having an issue with a Schindler 9700 the fault is an F8 bypass dropout check. It will not reset I am curious if anyone has had this fault and what the remedy is. I found it with the sis1 breakers tripped reset those cycled power the breakers did not trip again however the fault still did not go away. Also coming in is both the e-brake faults which do reset and I changed the e-brakes with a new one to verify that wasn’t the problem. Thanks for reading!
