1 members (ot1989), 104 guests, and 3 robots.
Engineer
Engineer
Anyone know of a unlocker tool that will unlock a Kone lce with 6.7.18 version software?
I've tried a relatively cheap unlocker tool and Modutool, both unsuccessful.
Dont think it can be done, KONE always put this software version in, when they the loose a unit.
Just update the software to a higher version, then use the LCEUIO or Modutool to unlock the interface.
/Alex
Engineer
Engineer
Can you help me through the process of updating the software?
Engineer
Engineer
Or can the KNX board unlock parameters?
pm on the way.....
Please kone unlock lce parametro cpu..thanks
if the drive still has the nvram, not the soldered memory, it will suffice to fill it with FF and put it back, but you will need to re-enter the install parameters. This process can be tedious if it is a device with special characteristics, if it is a standard device with a single entrance and without keys, all you have to do is read the hole to recognize the floors and address the remote stations (floor plates )
PHP: 8.3.36 Page Time: 0.025s Queries: 28 (0.009s) Memory: 3.0276 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 23:26:49 UTC
