0 members (), 14 guests, and 2 robots.
wiz
Greetings
We did a learning measurement trip on a schindler smart mrl 002 elevator using Dip Switch 8 on the main controller board. The lift learnt the floors, after the learnt trip it goes to the last floor
and shows the WDOG, Drive, KS, and Error LED blinking and remains on the last floor.
Anyone experience this problem, what causes it? Can it be corrected?
Regards
wiz
Originally Posted by wiz
Greetings
Anyone experience this problem, what causes it? Can it be corrected? No safety circuit open, but something is
blocking the lift from moving, any ideas?
Regards
sim
wiz
Are you saying the SIM card might be faulty or not in place properly but lift did a shaft measurement?
yes. it goes for learning trip although without sim and after trip if it can not read sim it behaves as you menioned.
wiz
Greetings
I tried re-inserting the sim. Is there a way to solve this problem besides replacing the SCIC?
Regards
maybe replacing SCIC may not be a solution. generally sim is broken. so if you have a bionic controller (bx, 3300 etc..) and also cadi you can check Sim. if not possible the company support should be requested.
PHP: 8.3.36 Page Time: 0.028s Queries: 28 (0.007s) Memory: 3.0283 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 13:20:37 UTC
