0 members (), 14 guests, and 2 robots.
#33547 07/31/22 10:51 PM
wiz
Greetings
I am using terminal with Smart.Trm on a Schindler smart mrl 002 elevator.
My connection is as follows male connector - female null modem - female null modem
- male RS232 connector to usb comm port 2 in terminal settings.
I can list the commands in terminal but I am not receiving data, anyone else had this issue.
What is your settings in terminal? Must I put on a dip switch?
Thank You
wiz
Greetings
Is the problem my RS232 cable?
can you show the cable photo by uploading
What version of the SCIC pcb do you have? Some the earlier ones had a different com setting then the later ones....
wiz
Greetings
My SCIC pcb Version 3.1. V3.1 is old. no wonder my RS232 to USB is not connecting. Anyone know if I can do a dip switch to look at errors on the COP?
Thanks Alex75 & Sampler.
wiz
Originally Posted by wiz
Greetings
Greetings
Anyone with pdf on SCIC PCB V3.1?
Bless
The com settings for a SCIC Q3.1 board shoud be as below....
Baud Rate 9600
Data Bit 8
Parity None
Stop Bit 1
Flow Control OFF
Any hyperterminal should be working or Cadi Bionic.
wiz
Baud Rate 9600
Data Bit 8
Parity None
Stop Bit 1
Flow Control OFF
Greetings
Used the SCIC 3.1 Com settings, shows the commands in both Cadi Bionic & Terminal but not receiving any data from the SCIC..
Also used a null modem.
Cheers
Alex75, do you know terminal can be used instead of cadi bionic for 3300 model
PHP: 8.3.36 Page Time: 0.032s Queries: 32 (0.008s) Memory: 3.0356 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-05 13:20:11 UTC
