#33919 09/21/22 03:06 PM
Lev
Dear all
I have attached a screeshot with marking. Can anyone tell me the meaning of it.
Regards
Levo
Not an Otis guy, but I'm thinking it's a variable capacitor or [i]maybe[i] a MOV. It's the only option that makes sense and not to far off from the modern symbol.
It shouldn't be to hard to figure out from looking at the full print or controller though.
It is a Dog shaft switch. Under the car, on the pull-out safeties shaft. A switch that has to be manually reset.
Lev
Dear LAmech,
This symbol shown across the normally close contact.
Regards
Lev
Yes, a capacitor across a contact will prevent an arc from forming when the contact begins to open, especially when there's an inductive load like a motor on the other end. Normally there's a resistor in series so the cap doesn't discharge as the contact closes and cause another arc. But if the power is cut from the relay, and the load discharges the cap before the relay drops, then I don't think you would need a resistor at all. And it being a variable variety would allow the mechanic to adjust it in the field until the arc is no longer seen instead of measures and doing math and ordering the needed size.
https://www.te.com/commerce/Documen...36_AppNote&DocType=CS&DocLang=EN the last page of this pamphlet describes what i'm talking about.
Not sure if this is the correct answer, just what I see when I look at the print.
Lev
Dear LAmech,
Yes. This is possibly a varistor. Thanks for your input.
Regards
Levo
I agree to this being a Varistor type component. Could be used as a suppressor or surge protection.
PHP: 8.3.33 Page Time: 0.023s Queries: 29 (0.006s) Memory: 3.0276 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-20 23:11:37 UTC
