#33964 09/29/22 07:39 PM
Working on a KONE Resolve 100. Another employee that is out on leave right now pulled the drive and MCU board out to be checked and repaired. Supposedly they have found nothing wrong with the drive or MCU board. I was sent to put it back in. I fire up the car and can’t access any 6 parameters and I comparing parameters on the adjacent car, carB, parameter 1-95 is set to 1. I can’t get 1-95 to save to a 1 on car A. Any thoughts on why I can’t access any 6 parameters or save 1-95 parameters?
Hi Twoblocked…
You most likely have a bad ram chip on your CPU-40 (right below SW chip) or a bad cpu altogether. My guess is the MCU and drive are fine. That’s a good running elevator. You will see this same problem in the future as CPU-40’s begin to age with all KONE equipment.
Originally Posted by Crimson76
Hi Twoblocked…
We got the car running the next day. That is exactly what the issue was though. The guy before me put a new CPU in and installed the original software and NVRAM chip. We found the old CPU and installed it with a new RAM chip and was able to change 1-95 parameter and access 6 parameters.
PHP: 8.3.36 Page Time: 0.032s Queries: 20 (0.007s) Memory: 3.0050 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 18:41:26 UTC
