#34344 12/07/22 09:03 PM
Hi. Can somebody recommend a filtration system to totally clear out water in oil after it’s changed
Jluff #34345 12/07/22 11:32 PM
Set up a bubbler in to blow bubbles in the bottom of your tank. It may sound crazy but it works. You can use a fish tank setup.
Jluff #34346 12/08/22 12:21 AM
Do you have a link for a specific model ?
Jluff #34349 12/08/22 01:56 PM
Did you use the weighted plastic tube set up ?
Jluff #34350 12/08/22 06:47 PM
Wurtec has filter elements for a filter cart that are designed to remove water. Never used them myself so can’t say if it works any better than a bubbler.
Jluff #34351 12/09/22 03:01 AM
We use an air bubbler and a heating element together, works great.
Jluff #34352 12/09/22 01:17 PM
Do you leave the car running with the air bubbler on ?
Jluff #34356 12/09/22 10:43 PM
You have to in order to bring contaminated oil back and forth from tank to jack(s)
Jluff #34357 12/09/22 10:48 PM
Will the oil heat up enough from normal use to make the bubbler effective or is some sort of heating element necessary?
Jluff #34360 12/10/22 04:25 PM
There was an outfit called CIA (no kidding) they showed up at an elevator convention selling pigs to remove oil from water. I told him I needed the opposite a pig tube or matt that would remove water from oil. Couple months later he said we have it now and we bought them wired them in the tank, so they didn't get sucked into the screen and they worked great. Probably 7 years ago and they were from the shipping port industry,
Jluff #34362 12/11/22 03:25 AM
Basic fish tank air stone works fine or rig up small pvc pipe and drill a bunch of little holes in it if the stone makes you nervous (that's what I did). It's all about getting water to evaporate at the surface so leave the lid open and keep a fan in the room. I've had heavy water contamination and it took a couple weeks but works great. Milk will turn to perfect looking oil haha, no joke.
Jluff #34387 12/16/22 05:22 AM
Gorman sells a filter pump just for this
PHP: 8.3.33 Page Time: 0.025s Queries: 38 (0.006s) Memory: 3.0490 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 00:49:03 UTC
