Can you install a new vf33 drive without a cadi service tool? Or can I take a drive from one car and install it in another without a cadi tool? Any insight on this process and commissioning would be appreciated. Thanks!
Sniper
Sniper
Does it have a valid sim card ?
If not then you will need cadi
Last time I did this, and it’s been a year or 2, the drives were coming with a software that isn’t compatible with the controller software in the US. The only way to get it to work was to get the correct drive software from Schindler or have them do it. After that it just needed a drive end commission.
Sniper
Sniper
You can use the front pc board of the old drive and replace the new one on the new drive, then you should have functionality to do zero position , dc link test etc
Even with cadi you cant do zero position test if you have software below v2.0
Ive done this mission already
Or if you can see the drive with cadi , get the tr position under drive parameters, drive settings TR and copy it to the new drive.
And Bobs you aunty
If you change out the tacho then you cant do that
Sniper
Sniper
You cant downgrade v²2 to v1_._ drive software
V2 is 2 and above
V1 is 1 up to 1.17 if im not mistaken
PHP: 8.3.36 Page Time: 0.040s Queries: 24 (0.012s) Memory: 3.0169 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 21:21:05 UTC
