#34661 01/31/23 08:45 PM
Gted
Gted
Hi there, I am having some on going issues that seems to be communication. I am not very familiar with the TAC20. Currently, my door operator is off line and WD on the board is not "ON".
I attached the pictures with the latest faults. I need to reconnect with the door operator and figure out what is the source for the car getting stuck.
Thank you for the help.
Elev8ted #34697 02/06/23 04:03 PM
Gted
Gted
Hello everyone, anyone having some inputs regarding this TAC20? Any help would be appreciated. Thank you.
Elev8ted #34698 02/06/23 05:21 PM
WD LED has to be on for the door board to function. Probably a bad door board but before replacing, check power supplies to it and for these older door boards the motor armature circuit has to be intact to get a WD.
Gted
Gted
Thank you, i will verify
Elev8ted #34704 02/07/23 10:08 PM
Gted
Gted
I checked the brushes on the motor, they looked fine.
I cheked my Ohms on my 188E board connector #23 and do have 99Ohms, only 101Ohms on the wires going back the the door operator comm.
Also have 0Vdc between PSC and NSC.
I think that it is a bad board.
Elev8ted #34880 03/09/23 02:13 AM
Gted
Gted
I had the board repaired and it worked. now having issues with valves i think. Fault 1087 and 1008(MCD/MCE). i had the relay replace before, but the oil looks really bad. i think that it trips once oil get warmer and get more fluid. did anyone had this type of issues before?
Thanks.
Elev8ted #34881 03/09/23 02:27 AM
I would replace all 8 valve coil relays as a starting point. I've had a decent amount of issues from those relays starting to go bad.
PHP: 8.3.36 Page Time: 0.030s Queries: 29 (0.009s) Memory: 3.0294 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 21:20:39 UTC
