0 members (), 74 guests, and 2 robots.
October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#34757 02/16/23 02:04 PM
I believe this is a southeastern controlled , but it’s labeled as a kiekafier , does anyone have a similar schematic I could use to help fill in the missing information. ? This is the best I could fill in the old faded print
If it is labeled Kiekhaefer in the controller it’s a very good chance the controller was made by CJ Anderson out of Chicago and private labeled for Kiekhaefer. CJ Anderson is still in business and impressively still has copies of prints for almost all the controllers they built. I have gotten replacement prints for jobs made in the 20s-30s from them.
Definitely not cj anderson , has these relay
Sure looks like the older southeasterns. Does it have that strange valve? I have some prints for southeastern you are welcome to if you like.
It is 100% an old Southeastern. I have (2) of them on my route. Unfortunately, no prints! I can tell you that 90% of the time the small shunt on the wafer relay brakes (as shown in the pictures you posted yellow wire). I have found that using "Super Flexible" wire from McMaster and soldering a new shunt will fix it better than a standard wire. Pull all the small shunts fix the broken ones then pull them again!!
PHP: 8.3.35 Page Time: 0.052s Queries: 26 (0.008s) Memory: 3.0173 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 02:02:39 UTC
